Time Before: 0.00366 seconds
Time After: 0.00613 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00630 seconds
Time After: 0.00681 seconds
Time Before: 0.00707 seconds
Time After: 0.00721 seconds
Time Before: 0.00800 seconds
Time After: 0.01021 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00728 seconds
Time After: 0.01510 seconds
Time Taken: 0.00781 seconds
Time Before: 0.01828 seconds
Time After: 0.01873 seconds
Time Before: 0.02017 seconds
Time After: 0.02135 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01751 seconds
Time After: 0.02158 seconds
Time Taken: 0.00408 seconds
Time Before: 0.03445 seconds
Time After: 0.03459 seconds
Time Before: 0.03891 seconds
Time After: 0.04013 seconds
End call of global.php: 0.042936086654663
Time Before: 0.04429 seconds
Time After: 0.04448 seconds
Time Before: 0.04775 seconds
Time After: 0.04923 seconds
SET lastactivity = 1776603164, location = '/forums/private.php?do=newpm&explain=1&u=37524'
Time Before: 0.06317 seconds
Time After: 0.06347 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.062246084213257 seconds with 9 queries, spending 0.0078182220458984 doing MySQL queries and 0.054427862167358 doing PHP things.
