Time Before: 0.02017 seconds
Time After: 0.02689 seconds
Time Taken: 0.00672 seconds
Time Before: 0.02697 seconds
Time After: 0.02740 seconds
Time Before: 0.02768 seconds
Time After: 0.02785 seconds
Time Before: 0.02868 seconds
Time After: 0.03135 seconds
Time Taken: 0.00267 seconds
Time Before: 0.02792 seconds
Time After: 0.03607 seconds
Time Taken: 0.00815 seconds
Time Before: 0.04375 seconds
Time After: 0.04422 seconds
Time Before: 0.04677 seconds
Time After: 0.04804 seconds
Time Before: 0.04294 seconds
Time After: 0.04833 seconds
Time Taken: 0.00539 seconds
Time Before: 0.08509 seconds
Time After: 0.08527 seconds
Time Before: 0.10098 seconds
Time After: 0.10225 seconds
Time Before: 0.11305 seconds
Time After: 0.11324 seconds
Time Before: 0.11581 seconds
Time After: 0.11724 seconds
UPDATE session SET lastactivity = 1776810036, location = '/forums/private.php?do=newpm&explain=1&u=37558', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.13561 seconds
Time After: 0.13594 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
