Time Before: 0.04057 seconds
Time After: 0.04732 seconds
Time Taken: 0.00675 seconds
Time Before: 0.04743 seconds
Time After: 0.04782 seconds
Time Before: 0.04810 seconds
Time After: 0.04824 seconds
Time Before: 0.04911 seconds
Time After: 0.05182 seconds
Time Taken: 0.00271 seconds
Time Before: 0.04830 seconds
Time After: 0.05622 seconds
Time Taken: 0.00792 seconds
Time Before: 0.06510 seconds
Time After: 0.06631 seconds
Time Before: 0.06907 seconds
Time After: 0.07028 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.06436 seconds
Time After: 0.07051 seconds
Time Taken: 0.00614 seconds
Memory After: 2,261.719 KB
Time Before: 0.13087 seconds
Time After: 0.13104 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.15552 seconds
Time After: 0.15702 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.16814 seconds
Time After: 0.16832 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.17094 seconds
Time After: 0.17236 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=3757' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.19284 seconds
Time After: 0.19311 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.469 KB
Memory Used: 0.250 KB
