Time Before: 0.00205 seconds
Time After: 0.00272 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00281 seconds
Time After: 0.00345 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00367 seconds
Time After: 0.00377 seconds
Time Before: 0.00439 seconds
Time After: 0.00844 seconds
Time Taken: 0.00405 seconds
Time Before: 0.00382 seconds
Time After: 0.01185 seconds
Time Taken: 0.00803 seconds
Time Before: 0.01440 seconds
Time After: 0.01472 seconds
Time Before: 0.01720 seconds
Time After: 0.01841 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01356 seconds
Time After: 0.01865 seconds
Time Taken: 0.00509 seconds
Memory After: 2,261.719 KB
Time Before: 0.02451 seconds
Time After: 0.02462 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02646 seconds
Time After: 0.02768 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.029320001602173
Time Before: 0.03091 seconds
Time After: 0.03103 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03373 seconds
Time After: 0.03533 seconds
Time Taken: 0.00160 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=37692'
Time Before: 0.04956 seconds
Time After: 0.04978 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.04862904548645 seconds with 9 queries, spending 0.0095841884613037 doing MySQL queries and 0.039044857025146 doing PHP things.
