Time Before: 0.00222 seconds
Time After: 0.00276 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00283 seconds
Time After: 0.00328 seconds
Time Before: 0.00348 seconds
Time After: 0.00361 seconds
Time Before: 0.00438 seconds
Time After: 0.00683 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00366 seconds
Time After: 0.01019 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01247 seconds
Time After: 0.01288 seconds
Time Before: 0.01637 seconds
Time After: 0.01762 seconds
Time Before: 0.01183 seconds
Time After: 0.01789 seconds
Time Taken: 0.00607 seconds
Time Before: 0.02457 seconds
Time After: 0.02471 seconds
Time Before: 0.02685 seconds
Time After: 0.02808 seconds
Time Before: 0.03104 seconds
Time After: 0.03121 seconds
Time Before: 0.03335 seconds
Time After: 0.03481 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=37718', badlocation = 1 WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04808 seconds
Time After: 0.04839 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
