Time Before: 0.00138 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00229 seconds
Time Before: 0.00252 seconds
Time After: 0.00265 seconds
Time Before: 0.00360 seconds
Time After: 0.00592 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00273 seconds
Time After: 0.01028 seconds
Time Taken: 0.00755 seconds
Time Before: 0.01243 seconds
Time After: 0.01280 seconds
Time Before: 0.01596 seconds
Time After: 0.01717 seconds
Time Before: 0.01165 seconds
Time After: 0.01743 seconds
Time Taken: 0.00578 seconds
Time Before: 0.02387 seconds
Time After: 0.02401 seconds
Time Before: 0.02632 seconds
Time After: 0.02760 seconds
End call of global.php: 0.030471801757812
Time Before: 0.03209 seconds
Time After: 0.03252 seconds
Time Before: 0.03559 seconds
Time After: 0.03702 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=37739'
Time Before: 0.05160 seconds
Time After: 0.05207 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.050668001174927 seconds with 9 queries, spending 0.0082082748413086 doing MySQL queries and 0.042459726333618 doing PHP things.
