Time Before: 0.01148 seconds
Time After: 0.01664 seconds
Time Taken: 0.00516 seconds
Time Before: 0.01674 seconds
Time After: 0.01742 seconds
Time Taken: 0.00068 seconds
Time Before: 0.01764 seconds
Time After: 0.01779 seconds
Time Before: 0.01850 seconds
Time After: 0.02113 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01783 seconds
Time After: 0.02540 seconds
Time Taken: 0.00756 seconds
Time Before: 0.03031 seconds
Time After: 0.03057 seconds
Time Before: 0.03206 seconds
Time After: 0.03326 seconds
Time Before: 0.02967 seconds
Time After: 0.03345 seconds
Time Taken: 0.00379 seconds
Time Before: 0.05219 seconds
Time After: 0.05234 seconds
Time Before: 0.06349 seconds
Time After: 0.06472 seconds
Time Before: 0.07332 seconds
Time After: 0.07347 seconds
Time Before: 0.07581 seconds
Time After: 0.07727 seconds
UPDATE session SET lastactivity = 1783038184, location = '/forums/private.php?do=newpm&explain=1&u=37756' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.09438 seconds
Time After: 0.09473 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
