Time Before: 0.01494 seconds
Time After: 0.01909 seconds
Time Taken: 0.00415 seconds
Time Before: 0.01920 seconds
Time After: 0.01978 seconds
Time Taken: 0.00058 seconds
Time Before: 0.02007 seconds
Time After: 0.02020 seconds
Time Before: 0.02100 seconds
Time After: 0.02360 seconds
Time Taken: 0.00259 seconds
Time Before: 0.02027 seconds
Time After: 0.02808 seconds
Time Taken: 0.00781 seconds
Time Before: 0.03163 seconds
Time After: 0.03212 seconds
Time Before: 0.03470 seconds
Time After: 0.03593 seconds
Time Before: 0.03096 seconds
Time After: 0.03617 seconds
Time Taken: 0.00521 seconds
Time Before: 0.06282 seconds
Time After: 0.06303 seconds
Time Before: 0.07350 seconds
Time After: 0.07480 seconds
End call of global.php: 0.077609062194824
Time Before: 0.08055 seconds
Time After: 0.08075 seconds
Time Before: 0.08410 seconds
Time After: 0.08555 seconds
SET lastactivity = 1784876548, location = '/forums/private.php?do=newpm&explain=1&u=37778'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.10361 seconds
Time After: 0.10393 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.1023850440979 seconds with 9 queries, spending 0.0085043907165527 doing MySQL queries and 0.093880653381348 doing PHP things.
