Time Before: 0.01478 seconds
Time After: 0.02086 seconds
Time Taken: 0.00608 seconds
Time Before: 0.02097 seconds
Time After: 0.02143 seconds
Time Before: 0.02167 seconds
Time After: 0.02181 seconds
Time Before: 0.02271 seconds
Time After: 0.02541 seconds
Time Taken: 0.00270 seconds
Time Before: 0.02189 seconds
Time After: 0.03044 seconds
Time Taken: 0.00854 seconds
Time Before: 0.03816 seconds
Time After: 0.03855 seconds
Time Before: 0.04122 seconds
Time After: 0.04250 seconds
Time Before: 0.03744 seconds
Time After: 0.04276 seconds
Time Taken: 0.00532 seconds
Time Before: 0.07666 seconds
Time After: 0.07681 seconds
Time Before: 0.08630 seconds
Time After: 0.08758 seconds
End call of global.php: 0.089601039886475
Time Before: 0.09368 seconds
Time After: 0.09384 seconds
Time Before: 0.09635 seconds
Time After: 0.09780 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=37891', badlocation = 1
Time Before: 0.11807 seconds
Time After: 0.11834 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.11699914932251 seconds with 9 queries, spending 0.0082457065582275 doing MySQL queries and 0.10875344276428 doing PHP things.
