Time Before: 0.01448 seconds
Time After: 0.02000 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02010 seconds
Time After: 0.02049 seconds
Time Before: 0.02067 seconds
Time After: 0.02080 seconds
Time Before: 0.02150 seconds
Time After: 0.02372 seconds
Time Taken: 0.00223 seconds
Time Before: 0.02086 seconds
Time After: 0.02742 seconds
Time Taken: 0.00655 seconds
Time Before: 0.03339 seconds
Time After: 0.03378 seconds
Time Before: 0.03516 seconds
Time After: 0.03635 seconds
Time Before: 0.03267 seconds
Time After: 0.03655 seconds
Time Taken: 0.00388 seconds
Time Before: 0.06333 seconds
Time After: 0.06347 seconds
Time Before: 0.07766 seconds
Time After: 0.07897 seconds
Time Taken: 0.00131 seconds
Time Before: 0.08884 seconds
Time After: 0.08900 seconds
Time Before: 0.09152 seconds
Time After: 0.09306 seconds
Time Taken: 0.00155 seconds
UPDATE session SET lastactivity = 1785342941, location = '/forums/private.php?do=newpm&explain=1&u=37895', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.11170 seconds
Time After: 0.11213 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
