Time Before: 0.00183 seconds
Time After: 0.00224 seconds
Time Before: 0.00231 seconds
Time After: 0.00285 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00307 seconds
Time After: 0.00319 seconds
Time Before: 0.00386 seconds
Time After: 0.00641 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00324 seconds
Time After: 0.00983 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01194 seconds
Time After: 0.01238 seconds
Time Before: 0.01475 seconds
Time After: 0.01594 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01137 seconds
Time After: 0.01611 seconds
Time Taken: 0.00474 seconds
Memory After: 2,261.719 KB
Time Before: 0.02201 seconds
Time After: 0.02213 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02414 seconds
Time After: 0.02538 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.027045011520386
Time Before: 0.02825 seconds
Time After: 0.02846 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03100 seconds
Time After: 0.03248 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=3792'
Time Before: 0.04719 seconds
Time After: 0.04760 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.469 KB
Memory Used: 0.250 KB
Page generated in 0.046208143234253 seconds with 9 queries, spending 0.0082921981811523 doing MySQL queries and 0.037915945053101 doing PHP things.
