Time Before: 0.01807 seconds
Time After: 0.02406 seconds
Time Taken: 0.00599 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02417 seconds
Time After: 0.02469 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02488 seconds
Time After: 0.02498 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02566 seconds
Time After: 0.02864 seconds
Time Taken: 0.00298 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02506 seconds
Time After: 0.03419 seconds
Time Taken: 0.00914 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04194 seconds
Time After: 0.04230 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04492 seconds
Time After: 0.04697 seconds
Time Taken: 0.00205 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04125 seconds
Time After: 0.04724 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08798 seconds
Time After: 0.08812 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.13660 seconds
Time After: 0.13789 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.14089202880859
Time Before: 0.16221 seconds
Time After: 0.16236 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.16673 seconds
Time After: 0.16821 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=37946', badlocation = 1
Time Before: 0.19176 seconds
Time After: 0.19203 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.19075298309326 seconds with 9 queries, spending 0.0093376636505127 doing MySQL queries and 0.18141531944275 doing PHP things.
