Time Before: 0.00246 seconds
Time After: 0.00294 seconds
Memory Before: 1,245.586 KB
Memory After: 1,272.391 KB
Time Before: 0.00302 seconds
Time After: 0.00375 seconds
Time Taken: 0.00073 seconds
Memory Before: 1,272.352 KB
Memory After: 1,273.328 KB
Time Before: 0.00401 seconds
Time After: 0.00419 seconds
Memory Before: 1,273.969 KB
Memory After: 1,274.492 KB
Time Before: 0.00486 seconds
Time After: 0.00782 seconds
Time Taken: 0.00297 seconds
Memory Before: 1,277.359 KB
Memory After: 1,278.281 KB
Time Before: 0.00424 seconds
Time After: 0.01262 seconds
Time Taken: 0.00838 seconds
Memory Before: 1,273.773 KB
Memory After: 2,354.992 KB
Memory Used: 1,081.219 KB
Time Before: 0.01454 seconds
Time After: 0.01491 seconds
Memory Before: 2,895.180 KB
Memory After: 2,895.797 KB
Time Before: 0.01710 seconds
Time After: 0.01851 seconds
Memory Before: 2,907.508 KB
Memory After: 2,907.367 KB
Time Before: 0.01394 seconds
Time After: 0.01873 seconds
Time Taken: 0.00478 seconds
Memory Before: 2,887.906 KB
Memory After: 3,020.422 KB
Memory Used: 132.516 KB
Time Before: 0.02521 seconds
Time After: 0.02548 seconds
Memory Before: 3,655.055 KB
Memory After: 3,655.570 KB
Time Before: 0.03310 seconds
Time After: 0.03440 seconds
Memory Before: 4,132.703 KB
Memory After: 4,133.297 KB
End call of global.php: 0.036072015762329
Time Before: 0.04409 seconds
Time After: 0.04429 seconds
Memory Before: 5,196.945 KB
Memory After: 5,325.289 KB
Time Before: 0.04731 seconds
Time After: 0.04880 seconds
Memory Before: 5,480.633 KB
Memory After: 5,610.234 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=38029', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.06196 seconds
Time After: 0.06231 seconds
Memory Before: 6,005.391 KB
Memory After: 6,005.609 KB
Page generated in 0.061081171035767 seconds with 9 queries, spending 0.0092694759368896 doing MySQL queries and 0.051811695098877 doing PHP things.
