Time Before: 0.00193 seconds
Time After: 0.00251 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00258 seconds
Time After: 0.00308 seconds
Time Before: 0.00334 seconds
Time After: 0.00349 seconds
Time Before: 0.00410 seconds
Time After: 0.00630 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00353 seconds
Time After: 0.01067 seconds
Time Taken: 0.00713 seconds
Time Before: 0.01309 seconds
Time After: 0.01359 seconds
Time Before: 0.01495 seconds
Time After: 0.01612 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01237 seconds
Time After: 0.01629 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02176 seconds
Time After: 0.02195 seconds
Time Before: 0.02474 seconds
Time After: 0.02644 seconds
Time Taken: 0.00170 seconds
End call of global.php: 0.029100179672241
Time Before: 0.03038 seconds
Time After: 0.03055 seconds
Time Before: 0.03252 seconds
Time After: 0.03409 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1776558604, location = '/forums/private.php?do=newpm&explain=1&u=38199'
Time Before: 0.04861 seconds
Time After: 0.04891 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.047645092010498 seconds with 9 queries, spending 0.008430004119873 doing MySQL queries and 0.039215087890625 doing PHP things.
