Time Before: 0.00271 seconds
Time After: 0.00362 seconds
Time Taken: 0.00091 seconds
Time Before: 0.00374 seconds
Time After: 0.00426 seconds
Time Before: 0.00450 seconds
Time After: 0.00469 seconds
Time Before: 0.00537 seconds
Time After: 0.00860 seconds
Time Taken: 0.00323 seconds
Time Before: 0.00474 seconds
Time After: 0.01358 seconds
Time Taken: 0.00884 seconds
Time Before: 0.01594 seconds
Time After: 0.01629 seconds
Time Before: 0.01918 seconds
Time After: 0.02139 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01534 seconds
Time After: 0.02163 seconds
Time Taken: 0.00629 seconds
Time Before: 0.02781 seconds
Time After: 0.02799 seconds
Time Before: 0.03062 seconds
Time After: 0.03243 seconds
Time Taken: 0.00181 seconds
End call of global.php: 0.034568071365356
Time Before: 0.03578 seconds
Time After: 0.03597 seconds
Time Before: 0.03820 seconds
Time After: 0.03965 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=38201'
Time Before: 0.06029 seconds
Time After: 0.06060 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.058844089508057 seconds with 9 queries, spending 0.010433197021484 doing MySQL queries and 0.048410892486572 doing PHP things.
