Time Before: 0.00142 seconds
Time After: 0.00197 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00204 seconds
Time After: 0.00241 seconds
Time Before: 0.00268 seconds
Time After: 0.00281 seconds
Time Before: 0.00361 seconds
Time After: 0.00568 seconds
Time Taken: 0.00206 seconds
Time Before: 0.00289 seconds
Time After: 0.00984 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01252 seconds
Time After: 0.01272 seconds
Time Before: 0.01554 seconds
Time After: 0.01674 seconds
Time Before: 0.01152 seconds
Time After: 0.01697 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02360 seconds
Time After: 0.02373 seconds
Time Before: 0.02600 seconds
Time After: 0.02749 seconds
End call of global.php: 0.029277086257935
Time Before: 0.03063 seconds
Time After: 0.03076 seconds
Time Before: 0.03301 seconds
Time After: 0.03444 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=38300'
Time Before: 0.04874 seconds
Time After: 0.04904 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047742128372192 seconds with 9 queries, spending 0.0074424743652344 doing MySQL queries and 0.040299654006958 doing PHP things.
