Time Before: 0.00144 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00241 seconds
Time Before: 0.00262 seconds
Time After: 0.00275 seconds
Time Before: 0.00349 seconds
Time After: 0.00594 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00279 seconds
Time After: 0.01014 seconds
Time Taken: 0.00735 seconds
Time Before: 0.01209 seconds
Time After: 0.01243 seconds
Time Before: 0.01496 seconds
Time After: 0.01632 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01148 seconds
Time After: 0.01663 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02299 seconds
Time After: 0.02333 seconds
Time Before: 0.02679 seconds
Time After: 0.02825 seconds
Time Before: 0.03189 seconds
Time After: 0.03208 seconds
Time Before: 0.03493 seconds
Time After: 0.03785 seconds
Time Taken: 0.00292 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=38452' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05231 seconds
Time After: 0.05296 seconds
Time Taken: 0.00065 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
