Time Before: 0.00149 seconds
Time After: 0.00219 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00231 seconds
Time After: 0.00274 seconds
Time Before: 0.00304 seconds
Time After: 0.00315 seconds
Time Before: 0.00394 seconds
Time After: 0.00643 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00321 seconds
Time After: 0.00997 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01188 seconds
Time After: 0.01218 seconds
Time Before: 0.01472 seconds
Time After: 0.01609 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01124 seconds
Time After: 0.01634 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02224 seconds
Time After: 0.02262 seconds
Time Before: 0.02463 seconds
Time After: 0.02624 seconds
Time Taken: 0.00161 seconds
End call of global.php: 0.027873039245605
Time Before: 0.02909 seconds
Time After: 0.02920 seconds
Time Before: 0.03110 seconds
Time After: 0.03248 seconds
SET lastactivity = 1789092291, location = '/forums/private.php?do=newpm&explain=1&u=38488'
Time Before: 0.04490 seconds
Time After: 0.04577 seconds
Time Taken: 0.00087 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.043892860412598 seconds with 9 queries, spending 0.009068489074707 doing MySQL queries and 0.034824371337891 doing PHP things.
