Time Before: 0.00804 seconds
Time After: 0.01122 seconds
Time Taken: 0.00318 seconds
Time Before: 0.01132 seconds
Time After: 0.01174 seconds
Time Before: 0.01198 seconds
Time After: 0.01210 seconds
Time Before: 0.01287 seconds
Time After: 0.01514 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01217 seconds
Time After: 0.01974 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02386 seconds
Time After: 0.02424 seconds
Time Before: 0.02694 seconds
Time After: 0.02818 seconds
Time Before: 0.02317 seconds
Time After: 0.02844 seconds
Time Taken: 0.00527 seconds
Time Before: 0.04164 seconds
Time After: 0.04181 seconds
Time Before: 0.05180 seconds
Time After: 0.05305 seconds
Time Before: 0.06009 seconds
Time After: 0.06026 seconds
Time Before: 0.06305 seconds
Time After: 0.06450 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=38494', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.07971 seconds
Time After: 0.07996 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
