Time Before: 0.00156 seconds
Time After: 0.00201 seconds
Time Before: 0.00209 seconds
Time After: 0.00249 seconds
Time Before: 0.00269 seconds
Time After: 0.00287 seconds
Time Before: 0.00359 seconds
Time After: 0.00660 seconds
Time Taken: 0.00301 seconds
Time Before: 0.00292 seconds
Time After: 0.01196 seconds
Time Taken: 0.00904 seconds
Time Before: 0.01389 seconds
Time After: 0.01429 seconds
Time Before: 0.01841 seconds
Time After: 0.01960 seconds
Time Before: 0.01328 seconds
Time After: 0.01979 seconds
Time Taken: 0.00651 seconds
Time Before: 0.02735 seconds
Time After: 0.02747 seconds
Time Before: 0.03057 seconds
Time After: 0.03179 seconds
Time Before: 0.03480 seconds
Time After: 0.03494 seconds
Time Before: 0.03710 seconds
Time After: 0.03855 seconds
UPDATE session SET lastactivity = 1784730620, location = '/forums/private.php?do=newpm&explain=1&u=38529' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05483 seconds
Time After: 0.05520 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
