Time Before: 0.00716 seconds
Time After: 0.01046 seconds
Time Taken: 0.00330 seconds
Time Before: 0.01055 seconds
Time After: 0.01100 seconds
Time Before: 0.01134 seconds
Time After: 0.01148 seconds
Time Before: 0.01226 seconds
Time After: 0.01501 seconds
Time Taken: 0.00274 seconds
Time Before: 0.01154 seconds
Time After: 0.01933 seconds
Time Taken: 0.00779 seconds
Time Before: 0.02465 seconds
Time After: 0.02489 seconds
Time Before: 0.02737 seconds
Time After: 0.02861 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02406 seconds
Time After: 0.02884 seconds
Time Taken: 0.00478 seconds
Memory After: 2,261.836 KB
Time Before: 0.04629 seconds
Time After: 0.04644 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05490 seconds
Time After: 0.05639 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.05862021446228
Time Before: 0.06216 seconds
Time After: 0.06231 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06495 seconds
Time After: 0.06645 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788878405, location = '/forums/private.php?do=newpm&explain=1&u=38578', badlocation = 1
Time Before: 0.08328 seconds
Time After: 0.08358 seconds
Memory Before: 4,288.734 KB
Memory After: 4,288.945 KB
Page generated in 0.082273006439209 seconds with 9 queries, spending 0.0083985328674316 doing MySQL queries and 0.073874473571777 doing PHP things.
