Time Before: 0.01449 seconds
Time After: 0.01785 seconds
Time Taken: 0.00336 seconds
Time Before: 0.01795 seconds
Time After: 0.01839 seconds
Time Before: 0.01861 seconds
Time After: 0.01878 seconds
Time Before: 0.01952 seconds
Time After: 0.02178 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01885 seconds
Time After: 0.02566 seconds
Time Taken: 0.00681 seconds
Time Before: 0.03077 seconds
Time After: 0.03117 seconds
Time Before: 0.03373 seconds
Time After: 0.03488 seconds
Time Taken: 0.00115 seconds
Time Before: 0.03001 seconds
Time After: 0.03508 seconds
Time Taken: 0.00507 seconds
Time Before: 0.05621 seconds
Time After: 0.05641 seconds
Time Before: 0.06278 seconds
Time After: 0.06403 seconds
Time Before: 0.07023 seconds
Time After: 0.07040 seconds
Time Before: 0.07263 seconds
Time After: 0.07410 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=38605', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.09170 seconds
Time After: 0.09196 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
