Time Before: 0.02052 seconds
Time After: 0.02969 seconds
Time Taken: 0.00917 seconds
Time Before: 0.02977 seconds
Time After: 0.03036 seconds
Time Taken: 0.00058 seconds
Time Before: 0.03059 seconds
Time After: 0.03077 seconds
Time Before: 0.03159 seconds
Time After: 0.03396 seconds
Time Taken: 0.00237 seconds
Time Before: 0.03084 seconds
Time After: 0.03834 seconds
Time Taken: 0.00750 seconds
Time Before: 0.04845 seconds
Time After: 0.04883 seconds
Time Before: 0.05116 seconds
Time After: 0.05238 seconds
Time Before: 0.04774 seconds
Time After: 0.05261 seconds
Time Taken: 0.00486 seconds
Time Before: 0.09212 seconds
Time After: 0.09234 seconds
Time Before: 0.11269 seconds
Time After: 0.11390 seconds
Time Before: 0.12861 seconds
Time After: 0.12881 seconds
Time Before: 0.13159 seconds
Time After: 0.13301 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=38707' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.15422 seconds
Time After: 0.15449 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
