Time Before: 0.00138 seconds
Time After: 0.00191 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00199 seconds
Time After: 0.00279 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00316 seconds
Time After: 0.00338 seconds
Time Before: 0.00406 seconds
Time After: 0.00668 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00345 seconds
Time After: 0.01009 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01187 seconds
Time After: 0.01239 seconds
Time Before: 0.01486 seconds
Time After: 0.01611 seconds
Time Before: 0.01126 seconds
Time After: 0.01629 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02196 seconds
Time After: 0.02214 seconds
Time Before: 0.02413 seconds
Time After: 0.02538 seconds
End call of global.php: 0.027086019515991
Time Before: 0.02841 seconds
Time After: 0.02861 seconds
Time Before: 0.03173 seconds
Time After: 0.03316 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=38728', badlocation = 1
Time Before: 0.04558 seconds
Time After: 0.04588 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.044686794281006 seconds with 9 queries, spending 0.0087714195251465 doing MySQL queries and 0.035915374755859 doing PHP things.
