Time Before: 0.00188 seconds
Time After: 0.00264 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00272 seconds
Time After: 0.00321 seconds
Time Before: 0.00349 seconds
Time After: 0.00363 seconds
Time Before: 0.00461 seconds
Time After: 0.00700 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00371 seconds
Time After: 0.01178 seconds
Time Taken: 0.00806 seconds
Time Before: 0.01496 seconds
Time After: 0.01538 seconds
Time Before: 0.01856 seconds
Time After: 0.01979 seconds
Time Before: 0.01411 seconds
Time After: 0.02009 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02764 seconds
Time After: 0.02780 seconds
Time Before: 0.03035 seconds
Time After: 0.03158 seconds
End call of global.php: 0.03326416015625
Time Before: 0.03458 seconds
Time After: 0.03472 seconds
Time Before: 0.03684 seconds
Time After: 0.03828 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=38801'
Time Before: 0.05104 seconds
Time After: 0.05151 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.050086975097656 seconds with 9 queries, spending 0.0081245899200439 doing MySQL queries and 0.041962385177612 doing PHP things.
