Time Before: 0.00140 seconds
Time After: 0.00194 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00201 seconds
Time After: 0.00252 seconds
Time Before: 0.00273 seconds
Time After: 0.00287 seconds
Time Before: 0.00361 seconds
Time After: 0.00665 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00292 seconds
Time After: 0.01004 seconds
Time Taken: 0.00713 seconds
Time Before: 0.01194 seconds
Time After: 0.01250 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01550 seconds
Time After: 0.01667 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01133 seconds
Time After: 0.01685 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02223 seconds
Time After: 0.02236 seconds
Time Before: 0.02411 seconds
Time After: 0.02539 seconds
End call of global.php: 0.026989221572876
Time Before: 0.02826 seconds
Time After: 0.02839 seconds
Time Before: 0.03043 seconds
Time After: 0.03190 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=3883', badlocation = 1
Time Before: 0.04627 seconds
Time After: 0.04663 seconds
Memory Before: 4,288.805 KB
Memory After: 4,289.031 KB
Page generated in 0.045183181762695 seconds with 9 queries, spending 0.0087907314300537 doing MySQL queries and 0.036392450332642 doing PHP things.
