Time Before: 0.01350 seconds
Time After: 0.02032 seconds
Time Taken: 0.00682 seconds
Time Before: 0.02039 seconds
Time After: 0.02100 seconds
Time Taken: 0.00061 seconds
Time Before: 0.02120 seconds
Time After: 0.02134 seconds
Time Before: 0.02217 seconds
Time After: 0.02467 seconds
Time Taken: 0.00251 seconds
Time Before: 0.02140 seconds
Time After: 0.02861 seconds
Time Taken: 0.00721 seconds
Time Before: 0.03859 seconds
Time After: 0.03899 seconds
Time Before: 0.04196 seconds
Time After: 0.04345 seconds
Time Before: 0.03781 seconds
Time After: 0.04366 seconds
Time Taken: 0.00585 seconds
Time Before: 0.07425 seconds
Time After: 0.07438 seconds
Time Before: 0.09433 seconds
Time After: 0.09559 seconds
End call of global.php: 0.097725868225098
Time Before: 0.10500 seconds
Time After: 0.10520 seconds
Time Before: 0.10754 seconds
Time After: 0.10904 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=3885', badlocation = 1
Time Before: 0.12871 seconds
Time After: 0.12909 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
Page generated in 0.12764000892639 seconds with 9 queries, spending 0.0086138248443604 doing MySQL queries and 0.11902618408203 doing PHP things.
