Time Before: 0.00457 seconds
Time After: 0.00783 seconds
Time Taken: 0.00326 seconds
Time Before: 0.00793 seconds
Time After: 0.00835 seconds
Time Before: 0.00859 seconds
Time After: 0.00877 seconds
Time Before: 0.00962 seconds
Time After: 0.01202 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00884 seconds
Time After: 0.01725 seconds
Time Taken: 0.00841 seconds
Time Before: 0.02120 seconds
Time After: 0.02160 seconds
Time Before: 0.02467 seconds
Time After: 0.02595 seconds
Time Before: 0.02059 seconds
Time After: 0.02622 seconds
Time Taken: 0.00563 seconds
Time Before: 0.03565 seconds
Time After: 0.03587 seconds
Time Before: 0.04267 seconds
Time After: 0.04412 seconds
End call of global.php: 0.045800924301147
Time Before: 0.04977 seconds
Time After: 0.04996 seconds
Time Before: 0.05234 seconds
Time After: 0.05379 seconds
SET lastactivity = 1789123732, location = '/forums/private.php?do=newpm&explain=1&u=38866'
Time Before: 0.06808 seconds
Time After: 0.06837 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.067121982574463 seconds with 9 queries, spending 0.0082690715789795 doing MySQL queries and 0.058852910995483 doing PHP things.
