Time Before: 0.02640 seconds
Time After: 0.03918 seconds
Time Taken: 0.01278 seconds
Time Before: 0.03930 seconds
Time After: 0.03975 seconds
Time Before: 0.03999 seconds
Time After: 0.04011 seconds
Time Before: 0.04092 seconds
Time After: 0.04344 seconds
Time Taken: 0.00252 seconds
Time Before: 0.04016 seconds
Time After: 0.04768 seconds
Time Taken: 0.00751 seconds
Time Before: 0.06182 seconds
Time After: 0.06227 seconds
Time Before: 0.06577 seconds
Time After: 0.06703 seconds
Time Before: 0.06108 seconds
Time After: 0.06730 seconds
Time Taken: 0.00622 seconds
Time Before: 0.11876 seconds
Time After: 0.11893 seconds
Time Before: 0.15083 seconds
Time After: 0.15207 seconds
Time Before: 0.16106 seconds
Time After: 0.16122 seconds
Time Before: 0.16407 seconds
Time After: 0.16554 seconds
UPDATE session SET lastactivity = 1783101095, location = '/forums/private.php?do=newpm&explain=1&u=38897' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.18401 seconds
Time After: 0.18439 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
