Time Before: 0.00244 seconds
Time After: 0.00321 seconds
Time Taken: 0.00077 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00330 seconds
Time After: 0.00388 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00412 seconds
Time After: 0.00425 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00496 seconds
Time After: 0.00759 seconds
Time Taken: 0.00263 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00430 seconds
Time After: 0.01101 seconds
Time Taken: 0.00671 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01310 seconds
Time After: 0.01353 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01605 seconds
Time After: 0.01721 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01231 seconds
Time After: 0.01739 seconds
Time Taken: 0.00508 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02362 seconds
Time After: 0.02380 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03071 seconds
Time After: 0.03192 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.033588886260986
Time Before: 0.04010 seconds
Time After: 0.04027 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04237 seconds
Time After: 0.04379 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=38899'
Time Before: 0.05716 seconds
Time After: 0.05746 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.056255102157593 seconds with 9 queries, spending 0.0081949234008789 doing MySQL queries and 0.048060178756714 doing PHP things.
