Time Before: 0.00137 seconds
Time After: 0.00186 seconds
Time Before: 0.00192 seconds
Time After: 0.00227 seconds
Time Before: 0.00247 seconds
Time After: 0.00259 seconds
Time Before: 0.00330 seconds
Time After: 0.00551 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00264 seconds
Time After: 0.00905 seconds
Time Taken: 0.00642 seconds
Time Before: 0.01083 seconds
Time After: 0.01131 seconds
Time Before: 0.01435 seconds
Time After: 0.01709 seconds
Time Taken: 0.00274 seconds
Time Before: 0.01021 seconds
Time After: 0.01727 seconds
Time Taken: 0.00706 seconds
Time Before: 0.02273 seconds
Time After: 0.02309 seconds
Time Before: 0.02523 seconds
Time After: 0.02646 seconds
End call of global.php: 0.028980016708374
Time Before: 0.03031 seconds
Time After: 0.03052 seconds
Time Before: 0.03249 seconds
Time After: 0.03408 seconds
Time Taken: 0.00159 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=38904', badlocation = 1
Time Before: 0.04671 seconds
Time After: 0.04695 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.045809984207153 seconds with 9 queries, spending 0.0095093250274658 doing MySQL queries and 0.036300659179688 doing PHP things.
