Time Before: 0.01379 seconds
Time After: 0.01971 seconds
Time Taken: 0.00593 seconds
Time Before: 0.01981 seconds
Time After: 0.02061 seconds
Time Taken: 0.00080 seconds
Time Before: 0.02103 seconds
Time After: 0.02122 seconds
Time Before: 0.02200 seconds
Time After: 0.02463 seconds
Time Taken: 0.00262 seconds
Time Before: 0.02128 seconds
Time After: 0.02911 seconds
Time Taken: 0.00783 seconds
Time Before: 0.03641 seconds
Time After: 0.03682 seconds
Time Before: 0.03816 seconds
Time After: 0.03945 seconds
Time Before: 0.03567 seconds
Time After: 0.03969 seconds
Time Taken: 0.00402 seconds
Time Before: 0.06474 seconds
Time After: 0.06494 seconds
Time Before: 0.07880 seconds
Time After: 0.08007 seconds
End call of global.php: 0.082312107086182
Time Before: 0.08695 seconds
Time After: 0.08715 seconds
Time Before: 0.08949 seconds
Time After: 0.09096 seconds
SET lastactivity = 1776447814, location = '/forums/private.php?do=newpm&explain=1&u=38968', badlocation = 1
Time Before: 0.11289 seconds
Time After: 0.11315 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.11146211624146 seconds with 9 queries, spending 0.0087215900421143 doing MySQL queries and 0.10274052619934 doing PHP things.
