Time Before: 0.00245 seconds
Time After: 0.00297 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00305 seconds
Time After: 0.00342 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00360 seconds
Time After: 0.00373 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00473 seconds
Time After: 0.00740 seconds
Time Taken: 0.00267 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00380 seconds
Time After: 0.01086 seconds
Time Taken: 0.00705 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01312 seconds
Time After: 0.01358 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01703 seconds
Time After: 0.01823 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01235 seconds
Time After: 0.01848 seconds
Time Taken: 0.00613 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.02582 seconds
Time After: 0.02599 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03310 seconds
Time After: 0.03433 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.036720037460327
Time Before: 0.04356 seconds
Time After: 0.04377 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.04635 seconds
Time After: 0.04789 seconds
Time Taken: 0.00154 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1769037896, location = '/forums/private.php?do=newpm&explain=1&u=38969'
WHERE sessionhash = 'aed90e65d11e22ea884774a0c30a33f2'
Time Before: 0.06370 seconds
Time After: 0.06438 seconds
Time Taken: 0.00068 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.062763929367065 seconds with 9 queries, spending 0.0086557865142822 doing MySQL queries and 0.054108142852783 doing PHP things.
