Time Before: 0.00212 seconds
Time After: 0.00284 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00290 seconds
Time After: 0.00353 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00377 seconds
Time After: 0.00391 seconds
Time Before: 0.00462 seconds
Time After: 0.00729 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00395 seconds
Time After: 0.01071 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01253 seconds
Time After: 0.01305 seconds
Time Before: 0.01577 seconds
Time After: 0.01701 seconds
Time Before: 0.01188 seconds
Time After: 0.01719 seconds
Time Taken: 0.00531 seconds
Time Before: 0.02219 seconds
Time After: 0.02248 seconds
Time Before: 0.02442 seconds
Time After: 0.02571 seconds
End call of global.php: 0.027328014373779
Time Before: 0.02855 seconds
Time After: 0.02880 seconds
Time Before: 0.03076 seconds
Time After: 0.03221 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=39037'
Time Before: 0.04463 seconds
Time After: 0.04488 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.043745040893555 seconds with 9 queries, spending 0.0087149143218994 doing MySQL queries and 0.035030126571655 doing PHP things.
