Time Before: 0.00164 seconds
Time After: 0.00212 seconds
Time Before: 0.00219 seconds
Time After: 0.00340 seconds
Time Before: 0.00392 seconds
Time After: 0.00404 seconds
Time Before: 0.00471 seconds
Time After: 0.00718 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00409 seconds
Time After: 0.01060 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01240 seconds
Time After: 0.01278 seconds
Time Before: 0.01507 seconds
Time After: 0.01629 seconds
Time Before: 0.01184 seconds
Time After: 0.01651 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02461 seconds
Time After: 0.02476 seconds
Time Before: 0.02691 seconds
Time After: 0.02824 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03146 seconds
Time After: 0.03163 seconds
Time Before: 0.03386 seconds
Time After: 0.03534 seconds
UPDATE session SET lastactivity = 1788992583, location = '/forums/private.php?do=newpm&explain=1&u=39108', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04912 seconds
Time After: 0.04939 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
