Time Before: 0.00297 seconds
Time After: 0.00361 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00369 seconds
Time After: 0.00419 seconds
Time Before: 0.00443 seconds
Time After: 0.00459 seconds
Time Before: 0.00570 seconds
Time After: 0.00959 seconds
Time Taken: 0.00390 seconds
Time Before: 0.00467 seconds
Time After: 0.01305 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01498 seconds
Time After: 0.01561 seconds
Time Before: 0.01797 seconds
Time After: 0.01920 seconds
Time Before: 0.01437 seconds
Time After: 0.01939 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02487 seconds
Time After: 0.02501 seconds
Time Before: 0.02750 seconds
Time After: 0.02870 seconds
End call of global.php: 0.03033185005188
Time Before: 0.03148 seconds
Time After: 0.03165 seconds
Time Before: 0.03355 seconds
Time After: 0.03499 seconds
SET lastactivity = 1788987629, location = '/forums/private.php?do=newpm&explain=1&u=39234', badlocation = 1
Time Before: 0.04764 seconds
Time After: 0.04803 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.046604871749878 seconds with 9 queries, spending 0.0097799301147461 doing MySQL queries and 0.036824941635132 doing PHP things.
