Time Before: 0.00145 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00316 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00362 seconds
Time After: 0.00409 seconds
Time Before: 0.00511 seconds
Time After: 0.00868 seconds
Time Taken: 0.00356 seconds
Time Before: 0.00418 seconds
Time After: 0.01404 seconds
Time Taken: 0.00986 seconds
Time Before: 0.01598 seconds
Time After: 0.01672 seconds
Time Taken: 0.00074 seconds
Time Before: 0.01921 seconds
Time After: 0.02041 seconds
Time Before: 0.01530 seconds
Time After: 0.02062 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02609 seconds
Time After: 0.02631 seconds
Time Before: 0.02876 seconds
Time After: 0.03047 seconds
Time Taken: 0.00171 seconds
Time Before: 0.03385 seconds
Time After: 0.03404 seconds
Time Before: 0.03664 seconds
Time After: 0.03806 seconds
UPDATE session SET lastactivity = 1789029244, location = '/forums/private.php?do=newpm&explain=1&u=39245' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05237 seconds
Time After: 0.05275 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
