Time Before: 0.00128 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00250 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00277 seconds
Time After: 0.00291 seconds
Time Before: 0.00360 seconds
Time After: 0.00636 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00296 seconds
Time After: 0.00990 seconds
Time Taken: 0.00694 seconds
Time Before: 0.01172 seconds
Time After: 0.01208 seconds
Time Before: 0.01326 seconds
Time After: 0.01454 seconds
Time Before: 0.01111 seconds
Time After: 0.01471 seconds
Time Taken: 0.00360 seconds
Time Before: 0.01983 seconds
Time After: 0.01996 seconds
Time Before: 0.02195 seconds
Time After: 0.02318 seconds
End call of global.php: 0.02481484413147
Time Before: 0.02601 seconds
Time After: 0.02616 seconds
Time Before: 0.02812 seconds
Time After: 0.02955 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=39273'
Time Before: 0.04241 seconds
Time After: 0.04276 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.041435956954956 seconds with 9 queries, spending 0.0084638595581055 doing MySQL queries and 0.032972097396851 doing PHP things.
