Time Before: 0.01715 seconds
Time After: 0.02892 seconds
Time Taken: 0.01178 seconds
Time Before: 0.02904 seconds
Time After: 0.02944 seconds
Time Before: 0.02969 seconds
Time After: 0.02983 seconds
Time Before: 0.03075 seconds
Time After: 0.03280 seconds
Time Taken: 0.00206 seconds
Time Before: 0.02989 seconds
Time After: 0.03730 seconds
Time Taken: 0.00741 seconds
Time Before: 0.04787 seconds
Time After: 0.04825 seconds
Time Before: 0.05114 seconds
Time After: 0.05239 seconds
Time Before: 0.04703 seconds
Time After: 0.05263 seconds
Time Taken: 0.00559 seconds
Time Before: 0.09086 seconds
Time After: 0.09100 seconds
Time Before: 0.11306 seconds
Time After: 0.11431 seconds
End call of global.php: 0.11669111251831
Time Before: 0.12411 seconds
Time After: 0.12425 seconds
Time Before: 0.12694 seconds
Time After: 0.12836 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=39399'
Time Before: 0.15199 seconds
Time After: 0.15231 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.15078687667847 seconds with 9 queries, spending 0.0075178146362305 doing MySQL queries and 0.14326906204224 doing PHP things.
