Time Before: 0.01593 seconds
Time After: 0.01996 seconds
Time Taken: 0.00404 seconds
Time Before: 0.02006 seconds
Time After: 0.02100 seconds
Time Taken: 0.00094 seconds
Time Before: 0.02138 seconds
Time After: 0.02149 seconds
Time Before: 0.02227 seconds
Time After: 0.02460 seconds
Time Taken: 0.00233 seconds
Time Before: 0.02156 seconds
Time After: 0.02894 seconds
Time Taken: 0.00738 seconds
Time Before: 0.03412 seconds
Time After: 0.03457 seconds
Time Before: 0.03720 seconds
Time After: 0.03839 seconds
Time Before: 0.03325 seconds
Time After: 0.03862 seconds
Time Taken: 0.00537 seconds
Memory After: 2,885.102 KB
Memory Used: 132.781 KB
Time Before: 0.06261 seconds
Time After: 0.06282 seconds
Memory Before: 3,438.195 KB
Memory After: 3,438.711 KB
Time Before: 0.07062 seconds
Time After: 0.07204 seconds
Memory Before: 3,525.867 KB
Memory After: 3,526.461 KB
End call of global.php: 0.074151039123535
Time Before: 0.07907 seconds
Time After: 0.07929 seconds
Memory Before: 4,163.750 KB
Memory After: 4,164.180 KB
Time Before: 0.08186 seconds
Time After: 0.08334 seconds
Memory Before: 4,445.289 KB
Memory After: 4,446.977 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=39452', badlocation = 1
Time Before: 0.10112 seconds
Time After: 0.10141 seconds
Memory Before: 4,910.969 KB
Memory After: 4,911.195 KB
Page generated in 0.099764108657837 seconds with 9 queries, spending 0.0086441040039062 doing MySQL queries and 0.091120004653931 doing PHP things.
