Time Before: 0.00225 seconds
Time After: 0.00294 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00304 seconds
Time After: 0.00345 seconds
Time Before: 0.00365 seconds
Time After: 0.00379 seconds
Time Before: 0.00448 seconds
Time After: 0.00683 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00384 seconds
Time After: 0.01104 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01308 seconds
Time After: 0.01361 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01659 seconds
Time After: 0.01792 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01224 seconds
Time After: 0.01810 seconds
Time Taken: 0.00585 seconds
Memory After: 2,261.836 KB
Time Before: 0.02336 seconds
Time After: 0.02349 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02596 seconds
Time After: 0.02729 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03138 seconds
Time After: 0.03159 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03376 seconds
Time After: 0.03521 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789029048, location = '/forums/private.php?do=newpm&explain=1&u=39458' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04772 seconds
Time After: 0.04804 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
