Time Before: 0.00142 seconds
Time After: 0.00191 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00198 seconds
Time After: 0.00243 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00268 seconds
Time After: 0.00280 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00353 seconds
Time After: 0.00593 seconds
Time Taken: 0.00241 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00285 seconds
Time After: 0.00935 seconds
Time Taken: 0.00650 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01115 seconds
Time After: 0.01160 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01456 seconds
Time After: 0.01575 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01056 seconds
Time After: 0.01592 seconds
Time Taken: 0.00536 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02118 seconds
Time After: 0.02136 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02350 seconds
Time After: 0.02478 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.026516914367676
Time Before: 0.02798 seconds
Time After: 0.02815 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03021 seconds
Time After: 0.03162 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=39462'
Time Before: 0.04405 seconds
Time After: 0.04437 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.043209075927734 seconds with 9 queries, spending 0.0079569816589355 doing MySQL queries and 0.035252094268799 doing PHP things.
