Time Before: 0.00152 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00262 seconds
Time Before: 0.00293 seconds
Time After: 0.00304 seconds
Time Before: 0.00382 seconds
Time After: 0.00644 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00309 seconds
Time After: 0.01049 seconds
Time Taken: 0.00739 seconds
Time Before: 0.01266 seconds
Time After: 0.01321 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01666 seconds
Time After: 0.01848 seconds
Time Taken: 0.00181 seconds
Time Before: 0.01188 seconds
Time After: 0.01865 seconds
Time Taken: 0.00676 seconds
Time Before: 0.02536 seconds
Time After: 0.02556 seconds
Time Before: 0.02760 seconds
Time After: 0.02897 seconds
Time Taken: 0.00136 seconds
Time Before: 0.03274 seconds
Time After: 0.03289 seconds
Time Before: 0.03503 seconds
Time After: 0.03684 seconds
UPDATE session SET lastactivity = 1789066734, location = '/forums/private.php?do=newpm&explain=1&u=39488' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05179 seconds
Time After: 0.05220 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
