Time Before: 0.03175 seconds
Time After: 0.04028 seconds
Time Taken: 0.00853 seconds
Time Before: 0.04039 seconds
Time After: 0.04082 seconds
Time Before: 0.04106 seconds
Time After: 0.04119 seconds
Time Before: 0.04205 seconds
Time After: 0.04448 seconds
Time Taken: 0.00243 seconds
Time Before: 0.04125 seconds
Time After: 0.04814 seconds
Time Taken: 0.00689 seconds
Time Before: 0.05391 seconds
Time After: 0.05433 seconds
Time Before: 0.05715 seconds
Time After: 0.05840 seconds
Time Before: 0.05324 seconds
Time After: 0.05868 seconds
Time Taken: 0.00544 seconds
Time Before: 0.10328 seconds
Time After: 0.10344 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"46.04,\";s:9:\"lastcheck\";i:1782918830;}', 1)Time Before: 0.12437 seconds
Time After: 0.12493 seconds
Time Taken: 0.00056 seconds
Memory Before: 2,817.273 KB
Memory After: 2,817.523 KB
Memory Used: 0.250 KB
Time Before: 0.14380 seconds
Time After: 0.14510 seconds
Memory Before: 2,904.578 KB
Memory After: 2,905.172 KB
Time Before: 0.15738 seconds
Time After: 0.15753 seconds
Memory Before: 3,541.367 KB
Memory After: 3,541.797 KB
Time Before: 0.16004 seconds
Time After: 0.16152 seconds
Memory Before: 3,823.109 KB
Memory After: 3,824.797 KB
UPDATE session SET lastactivity = 1782918830, location = '/forums/private.php?do=newpm&explain=1&u=39526' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.18121 seconds
Time After: 0.18152 seconds
Memory Before: 4,297.578 KB
Memory After: 4,297.805 KB
