Time Before: 0.02900 seconds
Time After: 0.04521 seconds
Time Taken: 0.01621 seconds
Time Before: 0.04529 seconds
Time After: 0.04578 seconds
Time Before: 0.04609 seconds
Time After: 0.04625 seconds
Time Before: 0.04699 seconds
Time After: 0.05010 seconds
Time Taken: 0.00311 seconds
Time Before: 0.04631 seconds
Time After: 0.05432 seconds
Time Taken: 0.00801 seconds
Time Before: 0.06390 seconds
Time After: 0.06409 seconds
Time Before: 0.06558 seconds
Time After: 0.06682 seconds
Time Before: 0.06315 seconds
Time After: 0.06703 seconds
Time Taken: 0.00388 seconds
Time Before: 0.12517 seconds
Time After: 0.12536 seconds
Time Before: 0.15957 seconds
Time After: 0.16083 seconds
End call of global.php: 0.162926197052
Time Before: 0.17051 seconds
Time After: 0.17068 seconds
Time Before: 0.17321 seconds
Time After: 0.17469 seconds
SET lastactivity = 1782836087, location = '/forums/private.php?do=newpm&explain=1&u=39777', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.19017 seconds
Time After: 0.19051 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.18921113014221 seconds with 9 queries, spending 0.0086307525634766 doing MySQL queries and 0.18058037757874 doing PHP things.
