Time Before: 0.00189 seconds
Time After: 0.00233 seconds
Time Before: 0.00241 seconds
Time After: 0.00282 seconds
Time Before: 0.00307 seconds
Time After: 0.00322 seconds
Time Before: 0.00421 seconds
Time After: 0.00705 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00330 seconds
Time After: 0.01211 seconds
Time Taken: 0.00881 seconds
Time Before: 0.01407 seconds
Time After: 0.01452 seconds
Time Before: 0.01784 seconds
Time After: 0.01911 seconds
Time Before: 0.01342 seconds
Time After: 0.01934 seconds
Time Taken: 0.00592 seconds
Time Before: 0.02531 seconds
Time After: 0.02572 seconds
Time Before: 0.02808 seconds
Time After: 0.02935 seconds
End call of global.php: 0.031677007675171
Time Before: 0.03324 seconds
Time After: 0.03339 seconds
Time Before: 0.03566 seconds
Time After: 0.03801 seconds
Time Taken: 0.00235 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=39835', badlocation = 1
Time Before: 0.05637 seconds
Time After: 0.05666 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.055433034896851 seconds with 9 queries, spending 0.0095927715301514 doing MySQL queries and 0.045840263366699 doing PHP things.
