Time Before: 0.00147 seconds
Time After: 0.00203 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00211 seconds
Time After: 0.00272 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00300 seconds
Time After: 0.00318 seconds
Time Before: 0.00396 seconds
Time After: 0.00651 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00323 seconds
Time After: 0.01064 seconds
Time Taken: 0.00741 seconds
Time Before: 0.01273 seconds
Time After: 0.01310 seconds
Time Before: 0.01540 seconds
Time After: 0.01689 seconds
Time Before: 0.01205 seconds
Time After: 0.01705 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02333 seconds
Time After: 0.02349 seconds
Time Before: 0.02533 seconds
Time After: 0.02675 seconds
End call of global.php: 0.029026985168457
Time Before: 0.03018 seconds
Time After: 0.03043 seconds
Time Before: 0.03247 seconds
Time After: 0.03392 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=39882', badlocation = 1
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04657 seconds
Time After: 0.04681 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.045670986175537 seconds with 9 queries, spending 0.0087239742279053 doing MySQL queries and 0.036947011947632 doing PHP things.
