Time Before: 0.00313 seconds
Time After: 0.00400 seconds
Time Taken: 0.00086 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00410 seconds
Time After: 0.00450 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00481 seconds
Time After: 0.00495 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00585 seconds
Time After: 0.00883 seconds
Time Taken: 0.00298 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00504 seconds
Time After: 0.01323 seconds
Time Taken: 0.00819 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01612 seconds
Time After: 0.01649 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01890 seconds
Time After: 0.02020 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01540 seconds
Time After: 0.02043 seconds
Time Taken: 0.00504 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.03125 seconds
Time After: 0.03141 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03880 seconds
Time After: 0.04004 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.041743993759155
Time Before: 0.04882 seconds
Time After: 0.04895 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.05118 seconds
Time After: 0.05266 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772951886, location = '/forums/private.php?do=newpm&explain=1&u=39906'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.06616 seconds
Time After: 0.06638 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.065171957015991 seconds with 9 queries, spending 0.0084183216094971 doing MySQL queries and 0.056753635406494 doing PHP things.
