Time Before: 0.01671 seconds
Time After: 0.02111 seconds
Time Taken: 0.00440 seconds
Time Before: 0.02125 seconds
Time After: 0.02245 seconds
Time Before: 0.02271 seconds
Time After: 0.02292 seconds
Time Before: 0.02374 seconds
Time After: 0.02593 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02301 seconds
Time After: 0.03035 seconds
Time Taken: 0.00734 seconds
Time Before: 0.03581 seconds
Time After: 0.03619 seconds
Time Before: 0.03765 seconds
Time After: 0.03888 seconds
Time Before: 0.03518 seconds
Time After: 0.03908 seconds
Time Taken: 0.00390 seconds
Time Before: 0.06217 seconds
Time After: 0.06230 seconds
Time Before: 0.07574 seconds
Time After: 0.07697 seconds
End call of global.php: 0.079006910324097
Time Before: 0.08407 seconds
Time After: 0.08423 seconds
Time Before: 0.08656 seconds
Time After: 0.08801 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=39954'
Time Before: 0.10575 seconds
Time After: 0.11409 seconds
Time Taken: 0.00834 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.10432696342468 seconds with 9 queries, spending 0.016517639160156 doing MySQL queries and 0.087809324264526 doing PHP things.
