Time Before: 0.00165 seconds
Time After: 0.00212 seconds
Time Before: 0.00233 seconds
Time After: 0.00305 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00339 seconds
Time After: 0.00358 seconds
Time Before: 0.00426 seconds
Time After: 0.00678 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00363 seconds
Time After: 0.01020 seconds
Time Taken: 0.00657 seconds
Time Before: 0.01220 seconds
Time After: 0.01257 seconds
Time Before: 0.01518 seconds
Time After: 0.01647 seconds
Time Before: 0.01161 seconds
Time After: 0.01664 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02148 seconds
Time After: 0.02167 seconds
Time Before: 0.02349 seconds
Time After: 0.02474 seconds
Time Before: 0.02744 seconds
Time After: 0.02763 seconds
Time Before: 0.02955 seconds
Time After: 0.03100 seconds
UPDATE session SET lastactivity = 1789082141, location = '/forums/private.php?do=newpm&explain=1&u=39986' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04318 seconds
Time After: 0.04354 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
